pathcontents(
PATH
The pathcontents( function lists the contents of a folder (specified by a path)
path – path to the folder to be listed.
This function lists the contents of a folder. Each listed file or folder is listed on a separate line.
pathcontents("~/Dropbox")
Note: This function is no longer necessary since the listfiles( function now performs the same function.
listfiles(path,"")
