enclosingfolder(
PATH
The enclosingfolder( function takes a full path and filename and returns the name of the folder that contains the file.
path – the original full path (may be in either HFS or UNIX format).
This function takes a full path and filename and returns the name of the folder that contains the file.
enclosingfolder("drive:folder:file.ext") ☞ folder
enclosingfolder("/Users/person/folder/file.ext") ☞ folder
10.0 | Updated | Carried over from Panorama 6.0, but automatically handles both UNIX and HFS paths. |
