subpath(
FOLDER
SUBFOLDER
The subpath( function returns the HFS path of a subfolder of a specified folder.
folder – the original folder
subfolder – the desired subfolder. This could be two or more levels deep, in which case each folder name should be separated by / (for compatibility with older versions of Panorama, a colon (:) is also accepted).
This function returns the HFS path of a subfolder of a specified folder.
subpath(info("userfolder"),"dropbox") ☞ Mercury HD:Users:markwilson:dropbox
See Files and Folders to learn more about HFS paths.
folderpath(thefolder)+replace(subfolder,":",info("foldersepchar"))
