foldercount(
PATH
The foldercount( function returns the total number of files within a folder (including any subfolders).
path – the path to the folder.
This function returns the total number of files within a folder (including any subfolders).
foldercount("~/Pictures") ☞ 3716
Note: This function can be slow if there are a lot of files in the specified folder.
Important: The foldercount( function counts all of the files in the folder, including hidden files. This means that the count returned by this function may be different than the number of files reported by the Finder.
