filefolder(
FILEPATH
The filefolder( function returns the folder ID of the folder that contains the specified file.
filepath – a combined path and file name. This may be either a UNIX path or an HFS path. (See Files and Folders for more information.)
This function returns the folder ID of the folder that contains the specified file.
filefolder("/Users/tomswift/Dropbox/PDF/Rocket Plans.pdf") ☞ /Users/tomswift/Dropbox/PDF
filefolder("~/Dropbox/PDF/Rocket Plans.pdf") ☞ /Users/tomswift/Dropbox/PDF
folder(filepath(thetext))
Note: In Panorama X, the folder ID is actually the same as the full path to the folder.
