listtextfiles(
FOLDER
The listtextfiles( function returns a list of text files in the specified folder.
folder – the path to the folder. See Files and Folders for details about file paths.
This function builds a text array listing the files in a folder. The items in the list are separated by the carriage return character (see Text Arrays).
This example will list all of the text files (which will primarily be .html files) at the root level of your personal web server:
listtextfiles("/Library/WebServer/")
listfiles(thefolder,"TEXT????")
