dbsubfolder(
SUBFOLDER
The dbsubfolder( function returns the path of a subfolder within the same folder as the current database.
subfolder – the desired subfolder. This could be two or more levels deep, in which case each folder name should be separated by / (for compatibility with older versions of Panorama, a colon (:) is also accepted).
This function returns the path of a subfolder within the same folder as the current database.
dbsubfolder("Images") ☞ /Users/johnsmith/My Databases/Images
folder(folderpath(dbinfo("folder",""))+replace(subfolder,":",info("foldersepchar")))
