filename(
FILEPATH
The filename( function extracts the filename from a complete path and filename.
filepath – a combined path and file name. This may be either a UNIX path or an HFS path. (See Files and Folders for more information.)
This function extracts the filename from a complete path and filename.
filename("/Users/patjohnson/Documents/Alaska/Denali23.jpg") ☞ Denali23.jpg
filename("HD:Trips:Family:July4.jpg") ☞ July4.jpg
array(thetext,arraysize(thetext,info("foldersepchar")),info("foldersepchar"))
