dbfolder(
The dbfolder( function returns the folder path of the folder the current database is located in.
This function returns the folder path of the folder the current database is located in.
dbfolder() ☞ /Users/tomswift/Documents/Accounting/
See Files and Folders for more information about paths and folder IDs.
dbinfo("folder","")
