The unixpath( function converts an HFS path into a UNIX path.
This function has one parameter:path – Original path, which may be in UNIX or HFS format. See Files and Folders to learn more about Folder IDs.
The unixpath( function takes a UNIX or HFS path and converts it to the UNIX path to that folder.
unixpath("~/Dropbox/Public/manifesto.pdf") ☞ Users/barbie/Dropbox/Public/manifesto.pdf
unixpath("Alaska:Projects:Bridge:plans.doc") ☞ /Volumes/Alaska/Projects/Bridge/plans.doc
Note: The unixpath( function has an alternate syntax that allows the folder and filename to be specified as separate parameters, like this:
hfspath(dbfolder(),"Logs") ☞ /Users/barbie/Documents/Databases/Logs
| Version | Status | Notes |
