filetypecreator(
PATH
The filetypecreator( function returns the type and creator code of the specified file (if any).
path – is a path to the file, including the file name (see Files and Folders for more information about file paths).
This function returns the type and creator code of the specified file (if any). The type code is a special 4 character codes that identifies the type of the file. The creator code is a special 4 character code that identifies what application created the file.
filetypecreator("/Users/tomswift/Dropbox/Photos/Boston City Flow.jpg") ☞ JPEG
filetypecreator("/Users/tomswift/Web/Home.html") ☞ TEXT
filetypecreator("/Users/tomswift/Movies/First Steps.mov") ☞ MOOV
Note: Type and creator codes are leftovers from Mac OS 9 and earlier. They are not used by modern systems. The filetypecreator( function determines the type/creator codes based on the extension at the end of the filename. (If the file does not have an extension, or if the extension is unknown to Panorama, the function returns ""
Common Type/Creator Codes
Here are some of the common type/creator codes that Panorama supports.
Type Code | Creator | Extensions | Notes |
ZEPD | KASX | .pandb | Panorama Database |
KSET | KASX | .panset | Panorama File Set |
TEXT | | .txt .html .css .csv | Text File |
JPEG | | .jpg .jpeg .jpe .jfif | JPEG Image File |
PNGf | | .png | PNG Image File |
TIFF | | .tiff .tif | TIFF Image File |
GIFf | | .gif | GIF Image File |
PICT | | .pict .pct .pic | PICT Image File (OS 9) |
BMPf | | .gif | BMP Image File (Windows) |
PDF | | .pdf | PDF Document (note space on end of type code) |
8BPS | | .psd | Photoshop File |
MOOV | | .mov .moov .qt | QuickTime Move File |
WAVE | | .wav | Audio File |
MPEG | | .mpg .mpeg .mp3 .mpe .mpa .mtv | MPEG Media File |
AIFF | | .aif .aiff | Audio File |
Legacy Syntax (Separate Folder and File Parameters)
In older versions of Panorama (6.0 and earlier) the filetypecreator( had two parameters, folderid and filename. To maintain compatibility with older databases, two parameters will still work, as shown in this example:
filetypecreator(folder("~/Documentation"),"news.txt")
For new databases you’ll probably find it easier to use the single parameter mode.
10.0 | Updated | Carried over from Panorama 6.0, but now may have either one parameter (path) or two (folder, path). |
