urlfilename(
URL
The urlfilename( function extracts the filename from a complete url.
url – an internet URL.
This function extracts the filename from a complete url.
urlfilename("http://www.provue.com/home.html") ☞ home.html
urlfilename("http://www.griffithobs.org/exhibits/all_space.html") ☞ all_space.html
urlfilename("http://tidbits.com/article/14079") ☞ 14079
array(thetext,arraysize(thetext,"/"),"/")
