longdatestr(
THEDATE
The longdatestr( function converts a date to text by spelling out the month.
thedate – a date to convert (usually created with the today() or date( functions).
Convert a date to text by spelling out the month.
longdatestr(today()) ☞ September 5th, 2013
longdatestr(date("last tuesday")) ☞ August 27th, 2013
longdatestr(date("friday")) ☞ September 6th, 2013
datepattern(thedate,"Month ddnth, YYYY")
- age( -- calculates a person's current age (in years) from their birthdate.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- years( -- converts a number of days into a number of years.
- yearsbetween( -- calculates the number of years between two dates.
