money(
NUMBER
The money( function converts a number to text, formatted as money.
number – a number representing a monetary value.
This function converts a number to text. The text will be formatted with commas every three digits and two digits after the decimal point.
money(5) ☞ 5.00
money(1234.5678) ☞ 1,234.57
money(98123.45) ☞ 98,123.45
Note: This function is equivalent to
pattern(number,"#.,##)
