completedatestr(
THEDATE
The completedatestr( function converts a date to text, spelling out the month and including the day of the week.
thedate – a date to convert (usually created with the today( or date( functions).
This function converts a date to text, spelling out the month and including the day of the week.
completedatestr(today()) ☞ Thursday, September 5th, 2013
completedatestr(date("last tuesday")) ☞ Tuesday, August 27th, 2013
completedatestr(date("friday")) ☞ Friday, September 6th, 2013
datepattern(thedate,"DayOfWeek, Month ddnth, YYYY")
- age( -- calculates a person's current age (in years) from their birthdate.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- years( -- converts a number of days into a number of years.
- yearsbetween( -- calculates the number of years between two dates.
