littleendianbinaryvalue(
DATA
The littleendianbinaryvalue( function converts little endian binary data (a byte, word, longword, or longlongword) into an unsigned number (see Binary Data).
data – is the binary value that you want to convert into an unsigned number. This value must be a byte, a word (2 bytes), a longword (4 bytes) or a longlongword (8 bytes).
This function converts little endian binary data (a byte, word, longword, or longlongword) into an unsigned number (see Binary Data).
littleendianbinaryvalue(hextobinary("B9")) ☞ 185
To learn more about big endian vs. little endian binary data, see Endianess in Wikipedia. Note: The binaryvalue( function reads data using the default endian format for the current processor. As of 2016, all processors used in Apple projects use little endian format.
