daystr(
THEDATE
The daystr( function converts a date to the day of the week (for example Sunday).
thedate – a date to convert (usually created with the today() or date( functions).
This function converts a date to the day of the week.
daystr(today()) ☞ Thursday
daystr(date("1/1/2014")) ☞ Wednesday
daystr(date("1/1/2015")) ☞ Thursday
datepattern(thedate,"DayOfWeek")
- age( -- calculates a person's current age (in years) from their birthdate.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- years( -- converts a number of days into a number of years.
- yearsbetween( -- calculates the number of years between two dates.
