dollarsandcents(
NUMBER
The dollarsandcents( function converts a number to text formatted as dollars and cents.
number – a number representing a monetary value.
This function converts a number to text formatted as dollars and cents.
dollarsandcents(5) ☞ Five dollars and 00 cents
dollarsandcents(12.75) ☞ Twelve dollars and 75 cents
dollarsandcents(1842.36) ☞ One thousand eight hundred forty-two dollars and 36 cents
pattern(number,"§ dollar~ and ¢¢ cents")
