eurodatestr(
THEDATE
The eurodatestr( function converts a date to text in European format.
thedate – a date to convert (usually created with the today( or date( functions).
This function converts a date to text in European format (for example 20-APR-2003).
eurodatestr(today()) ☞ 5-SEP-2013
eurodatestr(date("last tuesday")) ☞ 27-AUG-2013
eurodatestr(date("friday")) ☞ 6-SEP-2013
datepattern(thedate,"dd-MON-yyyy")
- age( -- calculates a person's current age (in years) from their birthdate.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- years( -- converts a number of days into a number of years.
- yearsbetween( -- calculates the number of years between two dates.
