binaryvalue(
DATA
The binaryvalue( function converts binary data (a byte, word, longword, or longlongword) into a number (see Binary Data).
data – is the binary value that you want to convert into a number. This value must be a byte, a word (2 bytes), a longword (4 bytes) or a longlongword (8 bytes).
This function converts binary data (a byte, word, longword, or longlongword) into a number (see Binary Data).
binaryvalue(word(987)) ☞ 987
Error Messages
binaryvalue( function data parameter must be a byte (8 bits), word (16 bits), longword (32 bits) or longlongword (64 bits). – This function does not work with arbitrary binary data, only data of the specified lengths.
10.0 | Updated | Carried over from Panorama 6.0, but now also supports 64 bit binary values. |
