monthmath(
DATE
OFFSET
The monthmath( function takes a date and computes the date that is one or more months before or after the original date.
date – is a number representing the original date.
offset – is the number of months to add or subtract from the date.
This function offsets a date by a number of months. For example, if you offset the date May 12, 1997 by two months the result is July 12, 1997. If you offset the same original date by minus two months the result is March 12, 1997.
If the new date does not exist because a month does not have enough days in it, the monthmath( function will pick the last day of the month. For example, if you offset March 31 by 1 month the result is April 30. If the new month lands in February the function knows about leap years and adjusts accordingly.
datepattern(monthmath(date("mar 31, 2012"),1),"Month ddnth, YYYY") ☞ April 30th, 2012
datepattern(monthmath(date("mar 31, 2012"),-1),"Month ddnth, YYYY") ☞ February 29th, 2012
datepattern(monthmath(date("mar 31, 2012"),2),"Month ddnth, YYYY") ☞ May 31st, 2012
datepattern(monthmath(date("mar 31, 2012"),12),"Month ddnth, YYYY") ☞ March 31st, 2013
Note: These examples assume the system’s Date & Time preferences are set to US format. If a non-US format is being used, the date values would have to be adjusted.
- calendardate( -- helps in creating monthly calendars.
- calendarday( -- helps in creating monthly calendars.
- datevalue( -- converts integer values for year, month and day into a number representing a date.
- dayofmonth( -- computes the day within a month.
- dayofquarter( -- computes the day within a quarter.
- dayofweek( -- computes the day of the week, with Sunday being 0, Monday 1, etc.
- dayofyear( -- computes the day within a quarter.
- dayvalue( -- extracts the day from a date as a numeric value.
- firstdayofweek( -- returns the user's preference for first day of the week.
- month1st( -- computes the first day of a month.
- monthlength( -- computes the length (number of days) of a month.
- monthvalue( -- extracts the month from a date as a numeric value.
- quarter1st( -- computes the first day of a quarter.
- quartervalue( -- extracts the quarter from a date as a numeric value.
- regulardate( -- extracts a regular date (number of days from January 1, 4713 B.C.) from a superdate.
- today( -- returns a number corresponding to today's date.
- week1st( -- computes the first day of a week (Sunday).
- weekvalue( -- extracts the week from a date as a numeric value.
- year1st( -- computes the first day of a year.
- yearvalue( -- extracts the year from a date as a numeric value.
