commastr(
NUMBER
The commastr( function converts a number to text, with a comma every third digit. The number is converted as an integer, with no decimal point.
number – a numeric value.
This function converts a number to text, with a comma every third digit. The number is converted as an integer, with no decimal point. If the parameter is text, it will be unchanged.
commastr(12345) ☞ 12,345
pattern(number,"#,")
