scientificnotation(
NUMBER
The scientificnotation( function converts a number to text, formatted in scientific notation.
number – a numeric value.
This function converts a number to text, formatted in scientific notation with three places after the decimal point (for example 9.812e+4).
scientificnotation(1) ☞ 1.000E+0
scientificnotation(98123.45) ☞ 9.812E+4
scientificnotation(0.0004789) ☞ 4.789E-4
pattern(number,"#.###E")
