hex(
VALUE
The hex( function converts a text item containing a hexadecimal number into a standard number (decimal).
value – is a text item that contains the hexadecimal number you want to convert.
Converts text with hexadecimal characters into a number.
hex("0C2") ☞ 194
hex("100") ☞ 256
If more than 16 hexadecimal digits are supplied, the result will be a binary data value.
hex("4142434445464748494a4b4c4d4e") ☞ ABCDEFGHIJKLMN
Note: If you want to convert hexadecimal digits to binary, a better method is probably to use the hextobinary( function. The hextobinary( function always produces a binary value, even if only one digit is supplied.
radix("hex",hexvalue)
| 10.0 | Updated | Carried over from Panorama 6.0, but now supports 64 bit values. If there are more than 16 digits hex supplied, the result will be a binary data value. Previous versions of Panorama would return binary data in a text value if there were more than 8 digits supplied. |
