datestr(
DATE
The datestr( function converts a date to text using format mm/dd/yy.
date – a date to convert (usually created with the today() or date( functions).
Convert a date to text using format mm/dd/yy.
datestr(today()) ☞ 9/3/13
datestr(date("last tuesday")) ☞ 8/27/13
datestr(date("friday")) ☞ 9/6/13
As shown above, if the month or day is a single digit, no leading zero will be added. If you want the leading zero, use this function:
datepattern(number),"MM/DD/YY")
See the datepattern( function for additional information.
datepattern(thedate,"mm/dd/yy")
- age( -- calculates a person's current age (in years) from their birthdate.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- years( -- converts a number of days into a number of years.
- yearsbetween( -- calculates the number of years between two dates.
