The pointsval( function converts a dimension to points (possibly from inches or centimeters).
This function has one parameter:dimension – original dimension. This can simply be a number, which is treated as points, or a number with a suffix of "
, in
, inch
, inches
, or cm
This function converts a dimension to points (possibly from inches or centimeters).
pointsval({100}) ☞ 100
pointsval({1"}) ☞ 72
pointsval({0.5 inches}) ☞ 36
pointsval({10 cm}) ☞ 283
10.0 | New | Carried over from Panorama 6.0 |
