rectanglecenter(
LARGERECTANGLE
SMALLRECTANGLE
The rectanglecenter( function adjusts a rectangle so that it is centered inside of another rectangle.
largerectangle – the larger rectangle.
smallrectangle – the smaller rectangle.
This function adjusts a rectangle so that it is centered inside of another rectangle. The procedure below creates a 1 inch square rectangle that is centered within the current screen dimensions.
MyRectangle=rectanglecenter(info("screenrectangle"),rectanglesize(0,0,72,72))
It’s actually possible for the “small” rectangle to be larger than the “large” rectangle. In that case, the “small” rectangle will be centered on the vertical and horizontal centers of the “large” rectangle. For example, this procedure will create a 2 inch rectangle that is centered on the currently pressed button.
MyRectangle=rectanglecenter(info("buttonrectangle"),rectanglesize(0,0,144,144))
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
