setrectanglewidth(
RECT
WIDTH
The setrectanglewidth( function changes the width of a rectangle, leaving the height unchanged.
rect – the original rectangle.
width – new width of the rectangle, in points.
This function changes the width of a rectangle, leaving the height unchanged. This example returns a rectangle with the same height as the current window, but a width of 50 points. This example sets the variable newRect to the height of the current window, but a width of 50 points.
let newRect = setrectanglewidth(info("windowrectangle"),50)
rectanglesize(rtop(therect),rleft(therect),rheight(therect),thewidth)
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
