rectanglestr(
RECTANGLE
The rectanglestr( function converts a rectangle into text in the format top,left,bottom,right.
rectangle – is the rectangle you want to get information about. See the rectangle( and rectanglesize( functions for additional information.
Converts a rectangle into text in the format top,left,bottom,right.
rectanglestr(rectangle(100,20,180,50)) ☞ 100,20,180,50
rectanglestr(info("screenrectangle")) ☞ 0,0,1080,1920
str(rtop(therect))+","+str(rleft(therect))+","+str(rbottom(therect))+","+str(rright(therect))
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
