integralpoint(
POINT
The integralpoint( function converts point coordinates to integers.
point – The point to convert.
Points have two coordinates, which can be floating point values. This function rounds both coordinates to the nearest integer value.
integralpoint(point(10.2, 20.8)) ☞ 10,21
Note: This function returns a point. If you want to see what the coordinates are in this point, use the pointstr( function.
