rheight(
RECTANGLE
The rheight( function extracts the height of a rectangle (see rectangle(, Graphic Coordinates).
rectangle – is the rectangle you want to get information about.
This function returns the height of the rectangle (in points). This width is expressed as a floating point number.
Error Messages
rheight( function requires a binary parameter. – The input to this function must be a binary value generated by the rectangle( function (or any other function that generates a binary rectangle value)
10.0UpdatedThis function returns a floating point number (Panorama 6 and earlier versions returned an integer value).
