The v( function returns the vertical position of a point (see point(, Graphic Coordinates).
This function has one parameter:rectangle – is a binary value that includes both the vertical and horizontal components of a position. This number is usually created with the point(, info(“click”), or info(“mouse”) functions.
This function returns the vertical position of the point in points (one point is 1/72 of an inch). This position is expressed as a floating point number.
Error Messages
v( function requires a binary parameter. – The input to this function must be a binary value generated by the point( function (or any other function that generates a binary point value)
10.0 | Updated | This function returns a floating point number (Panorama 6 and earlier versions returned an integer value). |
