rectangleadjust(
RECTANGLE
TOP
LEFT
BOTTOM
RIGHT
The rectangleadjust( function adjusts all four edges of a rectangle independently
This function has five parameters:
rectangle – the original rectangle to be adjusted.
top – is the distance the top edge of the rectangle will be moved. Positive numbers move the edge down, negative values move it up. Note: all distances are specified in points.
left – is the distance the left edge of the rectangle will be moved. Positive numbers move the edge to the right, negative to the left.
bottom – is the distance the bottom edge of the rectangle will be moved. Positive numbers move the edge down, negative values move it up.
right – is the distance the right edge of the rectangle will be moved. Positive numbers move the edge to the right, negative to the left.
This function adjusts all four edges of a rectangle independently. The procedure below creates a rectangle that is inset 20 points from all four edges of the screen.
MyRectangle=rectangleadjust(info("screenrectangle"),20,20,-20,-20)
The procedure below creates a rectangle that is the same size as the button rectangle but shifted 1 inch (72 points) to the right.
MyRectangle=rectangleadjust(info("buttonrectangle"),0,72,0,72)
