rwidth(
RECTANGLE
The rwidth( function extracts the width of a rectangle (see rectangle(, Graphic Coordinates).
rectangle – is the rectangle you want to get information about.
This function returns the width of the rectangle (in points). This width is expressed as a floating point number.
Error Messages
rleft( function requires a binary parameter. – The input to this function must be a binary value generated by the rectangle( function (or any other function that generates a binary rectangle value)
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
10.0 | Updated | This function returns a floating point number (Panorama 6 and earlier versions returned an integer value). |
