point(
V
H
The point( function combines vertical and horizontal co-ordinates into a single binary value that describes the position of a point (see Graphic Coordinates).
v – is the vertical position of the point. All dimensions are in points (1 points =1/72 inch).
h – is the horizontal position of the point.
The procedure below displays a message if you manage to click on a spot exactly 50 points from the top of the screen and 100 points from the left edge of the screen.
if info("click") = point(50,100)
    message "You hit the secret spot!"
else
    beep
10.0UpdatedCarried over from Panorama 6.0, but *V* and *H* parameters can now be floating point values, not just integers. The result is now a binary value, not an intenger.
