integralrectangle(
RECTANGLE
The integralrectangle( function converts rectangle coordinates to integers.
rectangle – The rectangle to convert.
Rectangles have four coordinates, which can be floating point values. This function rounds all four coordinates to the nearest integer value.
integralrectangle(rectanglesize(10.2, 20.8, 14.5, 19.1)) ☞ 10,21,15,19
Note: This function returns a rectangle, which is a binary value. If you want to see what the coordinates are in a rectangle, use the rectanglestr( or rectanglesizestr( function. The result shown above is from the rectanglesizestr( function.
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
