pointstr(
POINT
The pointstr( function converts a point value into text in the format v,h (for example 34,56).
point – point to be converted into text. See the point( function.
Converts a point value into text in the format V,H (for example 34,56).
pointstr(point(34,56)) ☞ 34,56
str(v(thepoint))+","+str(h(thepoint))
