setrectanglesize(
RECT
HEIGHT
WIDTH
The setrectanglesize( function changes the height and width of a rectangle, leaving the position of the top left hand corner unchanged.
rect – the original rectangle.
height – new height of the rectangle, in points.
width – new width of the rectangle, in points.
This function changes the height and width of a rectangle, leaving the position of the top left hand corner unchanged. This example creates a rectangle that is 200 points high and 500 points wide, with the upper left hand corner in the same position as the upper left hand corner of the current window.
setrectanglesize(info("windowrectangle"),200,500)
rectanglesize(rtop(therect),rleft(therect),theheight,thewidth)
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
