rectangleoffset(
RECTANGLE
VDISTANCE
HDISTANCE
The rectangleoffset( function offsets a rectangle to a new position.
rectangle – the original rectangle to be adjusted
vdistance – the vertical distance to move the rectangle. Positive numbers move the rectangle down, negative values move it up. Note: all distances are specified in points.
hdistance – the horizontal distance to move the rectangle. Positive numbers move the rectangle to the right, negative values move it to the left.
This function offsets (moves) a rectangle by a specified amount. The procedure below creates a rectangle that is the same size as the currently pressed button but positioned 1/2 inch below it and 1/2 inch to the right.
MyRectangle=rectangleoffset(info("buttonrectangle"),36,36)
- adjustxy( -- adjusts the four corners of a rectangle. However, only corners
that are inside a boundary are adjusted. Corners outside the boundary are left alone.
