nsrectstr(
THERECT
The nsrectstr( function converts a rectangle into text in the format x,y,width,height
therect – is the rectangle you want to get information about. See the nsrect(, rectangle( and rectanglesize( functions for additional information
This function converts a rectangle into text in the format x,y,width,height. It is similar to rectanglesizestr(, but this function lists the coordinates in the order used by the Cocoa NSMakeRect( function.
Note: The rectanglesizestr( function lists the coordinates in the order used by Bill Atkinson in Quickdraw (the original Mac 128 ROMs).
| 10.0 | New | Carried over from Panorama 6.0 |
