rectanglesizestr(
RECTANGLE
The rectanglesizestr( function converts a rectangle into text in the format top,left,height,width.
rectangle – is the rectangle you want to get information about. See the rectangle( and rectanglesize( functions for additional information.
Converts a rectangle into text in the format top,left,height,width.
rectanglesizestr(rectangle(100,20,180,50)) ☞ 100,20,80,30
rectanglesizestr(info("screenrectangle")) ☞ 0,0,1080,1920
This function is similar to the rectanglestr( function, which outputs the coordinates in the format, top,left,bottom,right.
str(rtop(therect))+","+str(rleft(therect))+","+str(rheight(therect))+","+str(rwidth(therect))
