rbottom(
RECTANGLE
The rbottom( function extracts the position of the bottom edge of a rectangle (see rectangle(, Graphic Coordinates).
rectangle – is the rectangle you want to get information about.
This function returns the position of the bottom edge of the rectangle (in points). This position is expressed as a floating point number.
Error Messages
rbottom( function requires a binary parameter. – The input to this function must be a binary value generated by the rectangle( function or any other function that generates a binary rectangle value.
10.0UpdatedThis function returns a floating point number (Panorama 6 and earlier versions returned an integer value).
