setrectangleheight(
RECT
HEIGHT
The setrectangleheight( function changes the height of a rectangle, leaving the width unchanged.
rect – the original rectangle.
height – new height of the rectangle, in points.
This function changes the height of a rectangle, leaving the width unchanged. This example returns a rectangle with the same width as the current window, but a height of 50 points.
setrectangleheight(info("windowrectangle"),50)
rectanglesize(rtop(therect),rleft(therect),theheight,rwidth(therect))
