rectangleinset(
RECTANGLE
DISTANCE
The rectangleinset( function insets a rectangle by a specified amount.
rectangle – the original rectangle to be adjusted.
distance – the distance (in points) to inset/outset the rectangle. If the distance is positive, the rectangle is made smaller. If the distance is negative, the rectangle is made larger.
This function insets a rectangle by a specified amount. The procedure below creates a rectangle that is inset 100 points from all four edges of the screen.
MyRectangle=rectangleinset(info("screenrectangle"),100)
If the distance is negative the rectangle will be enlarged. This procedure creates a rectangle that is 1/2 inch larger than the currently pressed button.
MyRectangle=rectangleinset(info("buttonrectangle"),-36)
