nsrect(
X
Y
WIDTH
HEIGHT
The nsrect( function defines a rectangle using the same parameter order as the Cocoa NSMakeRect( function.
x – is the position of the left edge of the rectangle. (Like standard cartesian co-ordinates, positive is right and negative is left.)
y – is the position of the top edge of the rectangle. (Unlike standard cartesian co-ordinates, positive is down and negative is up.)
width – is the width of the rectangle.
height – is the height of the rectangle.
This function defines a rectangle. It is similar to rectanglesize(, but the coordinates are listed in the order used by the Cocoa NSMakeRect( function.
Note: The rectanglesize( function lists the coordinates in the order used by Bill Atkinson in Quickdraw (the original Mac 128 ROMs).
| 10.0 | =New | New in this version. |
