Implementing channels took the most time, nearly a week. This release also includes many small changes made in preparing the Keynote slides for upcoming sessions.
Reduced size of Panorama.app by nearly 80%. Your databases may get a bit smaller also if you have large procedures (you’ll need to recompile them).
Implemented channels, including preference panel for channel settings, channel statements and functions, and statements for dialing the phone and sending email.
New tags for the ConstructFormDataEditors statement, including <width>, <button>, <buttons>, <help> (tooltips) and <code>.
New “Large Text” Formula Workshop window.
New Recompile statement, and added recompile option to View Organizer wizard.
Find/Select dialog is empty/is not empty options now work with any data type.
Fixed missing information in form blueprints, including static images, groups, and text labels.
The arraycontains( and arraynotcontains( functions now work with data arrays.
The GetDictionaryValue( function and statement now have an additional optional parameter that specifies a default value to return if the dictionary item doesn’t exist.
SetDictionaryValue statement now allows multiple key/value pairs to change multiple values with a single statement.
The timestampstr( function now works correctly for all times of day.
Fixed bugs in Perl, PHP, Python and Ruby statements. Most of these bugs had already been fixed for Perl, but the fixes had not been applied to the other languages.
Fixed crash that occurs when importing a Panorama 6 database with no permenent variables
The listfiles( function will now accept one 4 character type code, in addition to 1 or more 8 character type codes.
Numerous documentation corrections submitted by Crag McPherson – thank you Craig!
- channelcatalog -- The channelcatalog statement creates a list of all channel databases (including the path for each database).
- crtolf( -- The crtolf( function converts carriage returns into linefeeds.
- divzeroerror( -- The divzeroerror( function divides two numbers, returns an error if the denominator is zero.
- infinity( -- The infinity( function returns infinity.
- lftocr( -- The lftocr( function converts linefeeds into carriage returns.
- recompile -- The recompile statement recompiles all procedures in a database.
- signedbinaryvalue( -- The signedbinaryvalue( function converts binary data (a byte, word, longword, or longlongword) into a signed number (see Binary Data).
- channelcall -- The channelcall statement calls a procedure in the active channel module.
- channelpath -- The channelpath statement returns the path of a specified channel module.
- channelactivemodule( -- The channelactivemodule( function returns the currently active module for a channel, if any.
- channelactivemodule -- The channelactivemodule statement returns the currently active module for a channel, if any.
- channelgetdictionary -- The channelgetdictionary statement returns the current settings for a specified channel.
- channelinformation( -- The channelinformation( function returns information about a specified channel.
- channelinformation -- The channelinformation statement returns information about a specified channel.
- channelload -- The channelload statement loads a channel module.
- channelmodules( -- The channelmodules( function returns a list of available modules for a specified channel type.
- channelmodules -- The channelmodules statement returns a list of available modules for a specified channel type.
- channelopen -- The channelopen statement opens a channel module for editing.
- channelpath( -- The channelpath( function returns the path of a specified channel module.
- channelprocedures -- The channelprocedures statement returns a list of procedures available in a specified channel.
- channelswitch -- The channelswitch statement switches the active channel module.
- channeltypes( -- The channeltypes( function returns a list of available channel types.
- channeltypes -- The channeltypes statement returns a list of available channel types.
- dialdigits -- The dialdigits statement dials one or more digits.
- dialphone -- The dialphone statement dials one or more digits, adjusting for area codes, country codes, etc..
- sendarrayemail -- The sendarrayemail statement sends a single e-mail to multiple recipients.
- sendbulkemail -- The sendbulkemail statement sends a single e-mail to multiple recipients.
- sendemail -- The sendemail statement sends an e-mail. It gives access to the maximum number of options available.
- sendoneemail -- The sendoneemail statement sends a single e-mail to a single recipient.
- / -- The / operator divides one numeric value by another.
- channelsetdictionary -- The channelsetdictionary statement saves new settings for a specified channel.
- encodebase64( -- The encodebase64( function encodes data using Base64.
- formcolor -- The formcolor statement changes the background color of the current form.
- getaddress -- The getaddress statement divides the last line of an address into separate components.
- getinternalbutton -- The getinternalbutton statement retrieves the coordinates of the last button that was pressed (in form relative coordinates).
- getlocalbutton -- The getlocalbutton statement retrieves the coordinates of the last button that was pressed (in window relative coordinates).
- getname -- The getname statement divides a person's full name into separate components.
- gettextdialog -- The gettextdialog statement displays a configurable modal dialog that asks the user to enter an item of text.
- getwebcolor -- The getwebcolor statement will calculate an RGB color from a Netscape style web color.
- gotofielddialog -- The gotofielddialog statement opens the standard dialog for jumping to a specific field (in the Fields menu).
- htmldatamerge -- The htmldatamerge statement uses a template to generate HTML you want from a database.
- importjsonline -- The importjsonline statement imports a JSON record into the current record.
- info("guid") -- The info("guid") function returns a unique identifier string.
- info("timerinfo") -- The info("timerinfo") function returns a dictionary that contains all of the properties of the currently running timer.
- insertbelowcarriagereturn -- The insertbelowcarriagereturn statement inserts a new record below the current record and moves to the first column.
- listpanoramafiles( -- The listpanoramafiles( function returns a list of panorama database files in the specified folder.
- local -- The local statement creates one or more local variables.
- makefilesecret -- The makefilesecret statement closes all of the windows associated with a file, but keeps the file open in memory.
- md5( -- The md5( function calculates the MD5 hash of a binary or text data item.
- sha256( -- The sha256( function calculates the SHA-256 hash of a binary or text data item.
