Lots and lots of adjustments and bug fixes, over 50 commits to the Git repository in only a week!
- Added Rich Text checkbox to Text Display object.
- Improved arrangement and operation of font selection in the Text properties panel (Graphics Mode). Now allow selection of “virtual” system fonts that adjust automatically when OS X is updated (i.e. Helvetica-Neue in 10.10, San Francisco in 10.11).
- Implemented background colors for forms, including import from Panorama 6 and ability to set the background color both in the UI and via a procedure.
- Data entry of dates now works properly in countries that use DD/MM/YY format, like Australia.
- Implemented the saveas and saveacopyas statements :)
- Corrected opendatabase, opensecret and openfile to work with HFS paths and partial paths.
- Fixed bug that could cause up/down actions to land on an unselected record.
- An empty floating point cell now reliably returns zero.
- Find/Select dialog now works correctly for field names that have spaces or punctuation in them.
- Fixed search preferences in the Preferences dialog.
- Fixed the fileexistspath( function.
- Fixed processing of single/double quotes inside pipe quotes.
- No longer prints report tiles in different colors (this was for debugging, forgot to remove it earlier).
- When printing, Panorama now generates a fake 8.5 by 11 data tile at 0,0 if there is no data tile in the form (previously it would hang).
- Now correctly imports Panorama 6 fixed point data cells that are empty (they stay empty, instead of getting a zero value).
- 14 statements didn’t properly check for the minimum number of parameters. This could cause a Panorama 6 database to fail to import into Panorama X.
- Added the not( function, which wasn’t documented in Panorama 6, but apparently has been there for a long time.
- Implemented the hide and show statements. These are now identical to noshow and endnowshow/showpage.
- Text Display objects in Literal Text mode (simulates Panorama 6 Auto-Wrap Text) now works even if a formula { } contains chevron characters « and ».
- Added the following statements that were in Panorama 6 but not documented: AddLine, CopyLine, CutLine, DeleteLine, InsertLineBelow, InsertLine, PasteLine. Note: These are still not documented!
- The until statement now can be followed by the keyword stopped, just like Panorama 6 and earlier.
- Control-clicking on data sheet column header now changes the current field to the clicked on field (just like right clicking).
- No longer displays a notification if you choose a menu item that is a parent of a submenu.
- Fixed the doubleclick( function.
- The define statement now creates a fileglobal variable if the destination variable doesn’t exist. This matches the behavior of Panorama 6.
- When specifying a rectangle in form creation/modification statements (newformobject, changeobject, changeobjects) Panorama no longer crashes if the supplied parameter is not a valid rectangle. Similar fixes for some point functions.
- The Check tool now always recompiles the procedure, even if it hasn’t changed.
- The Database Code Errors dialog in the View Organizer now has a recheck button, which can be used if you think some procedures might work now (for example if you are using a newer version of Panorama X).
- Eliminated brief error message flash for superalert, displaydata, superchoicedialog, etc.
- Added the OpenMacro statement as a synonym for openprocedure (for really, really ancient code).
- Fixed RTML parser so that it recognizes a tag at the very end of the text.
- localparameters -- The localparameters statement creates one or more local variables and assigns parameter values to them.
- makemergeformula( -- The makemergeformula( function builds a formula from an “auto-wrap" style merge template.
- hide -- The hide statement temporarily disables the output of text and graphics.
- info("formcolor") -- The info("formcolor") function returns the background color of the current form.
- noundo -- The noundo statement does nothing (it used to disable undo).
- saveacopyas -- The saveacopyas statement saves a copy of the currently active file under a new name. The original database remains open in memory under its original name.
- saveas -- The saveas statement saves a copy of the currently active file under a new name. The original file remains unchanged.
- show -- The show statement resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- formcolor -- The formcolor statement changes the background color of the current form.
- not( -- The not( function reverses a Boolean value
- Panorama Help Wizard -- learn how to get the most from Panorama's online help wizard, including choosing a realm, searching for a specific topic, and opening multiple help windows.
- define -- The define statement performs an assignment, much like an equals sign or the assign statement. However, the define statement only performs the assignment if the variable is currently undefined. If the variable already has a value, the define statement leaves it alone. The define statement is especially useful for initializing permanent variables.
