This is not a blockbuster update by any means, but quite a few small changes have accumulated.
In a formula, empty date fields are now treated as zero rather than as January 24, 1984.
When deleting one or more form objects, the object properties panel is now updated to show that no objects are selected any more.
Auto-save is now disabled when editing form object properties.
Added the SetActiveDatabase statement, as an alternative to “secret” windows.
Added the loopdataarray statement.
Added new functions replacefirst(, regexreplacefirst(, and regexreplacefirstexact(. Unlike the regular replace functions, these only replace the first occurence of the matched text.
The grabdata( function now allows the first parameter to be omitted, in which case the current database is assumed. Also, fieldvalue( is now a synonym for this function.
Added multiple statements and functions (see below) for directly accessing fields and variables at specific levels. This allows a programmer to bypass Panorama’s normal hierarchy of data storage/access.
The binaryvalue( function now returns unsigned values. Removed the unsignedbinaryvalue( function and replaced it with the signedbinaryvalue( function. Added two new functions, bigendianbinaryvalue( and littleendianbinaryvalue(, both of which return unsigned values.
Implemented MactoUTF8 and UTF8toMac functions and statements (for legacy compatibility, they don’t actually do anything).
Fixed import of Choice format from Panorama 6 (would fail if digits was set to non-zero values, now it works).
Allow loose colons between statements in a procedure. Panorama 1.0 allowed (actually required) colons in between formulas in the design sheet, and at least one developer still had colons in his databases!
When importing procedure mode formulas from Panorama 6, no longer converts a blank line into call "".
Fixed MatrixButtonHelper statement.
Fixed checkedmenuitem( function
The info(“bof”) and info(“eof”) functions now work correctly with arraybuild and export. Note that with arraybuild, info(“bof”) might not be the first record included, and info(“eof”) might not be the last, this only happens if you’ve told it to include only selected records.
- assignfield -- The assignfield statement performs an assignment, much like an equals sign or the assign statement. However, the assignfield statement only performs the assignment to a database field, not to any variable.
- assignfileglobal -- The assignfileglobal statement performs an assignment, much like an equals sign or the assign statement. However, the assignfileglobal statement only performs the assignment to a fileglobal variable.
- assignglobal -- The assignglobal statement performs an assignment, much like an equals sign or the assign statement. However, the assignglobal statement only performs the assignment to a global variable.
- assignlocal -- The assignlocal statement performs an assignment, much like an equals sign or the assign statement. However, the assignlocal statement only performs the assignment to a local variable.
- assignwindowglobal -- The assignwindowglobal statement performs an assignment, much like an equals sign or the assign statement. However, the assignwindowglobal statement only performs the assignment to a windowglobal variable.
- bigendianbinaryvalue( -- The bigendianbinaryvalue( function converts big endian binary data (a byte, word, or longword) into an unsigned number (see Binary Data).
- globalvalue( -- The globalvalue( function returns the value of a global variable.
- littleendianbinaryvalue( -- The littleendianbinaryvalue( function converts little endian binary data (a byte, word, longword, or longlongword) into an unsigned number (see Binary Data).
- localvalue( -- The localvalue( function returns the value of a local variable.
- loopdataarray -- The loopdataarray statement is used at the beginning of a loop that loops over the elements of a data array.
- regexreplacefirst( -- The regexreplacefirst( function replaces the first occurrence of a regular expression pattern with new text.
- regexreplacefirstexact( -- The regexreplacefirstexact( function replaces the first occurrence of a regular expression pattern with new text.
- replacefirst( -- The replacefirst( function replaces the first occurence of some text with new text.
- setactivedatabase -- The setactivedatabase statement makes a database active (without changing the configuration of the windows).
- setfield -- The setfield statement performs an assignment, much like an equals sign or the assign statement. However, the destination field of the assignment can be calculated on the fly.
- setfileglobal -- The setfileglobal statement sets the value of a fileglobal variable (optionally in another database).
- setglobal -- The setglobal statement sets a value into a global variable. The name of the global variable is calculated on the fly.
- setlocal -- The setlocal statement sets a value into a local variable. The name of the local variable is calculated on the fly.
- setwindowglobal -- The setwindowglobal statement sets the value of a windowglobal variable (optionally in another window).
- mactoutf8( -- The mactoutf8( function translates text from Panorama format to UTF8 (Unicode).
- mactoutf8 -- The mactoutf8 statement translates text from Panorama format to UTF8 (Unicode).
- utf8tomac( -- The utf8tomac( function translates text from UTF8 (Unicode) into Panorama's native text format.
- utf8tomac -- The utf8tomac statement translates text from UTF8 (Unicode) to Panorama format.
- fileglobalvalue( -- The fileglobalvalue( function accesses a fileglobal or permanent variable from other databases.
- opendialogsheet -- The opendialogsheet statement opens a form from the current database as a sheet dialog (attached to the current window).
- regexreplace( -- The regexreplace( function replaces text with new text. The text to be replaced is determined by a regular expression.
- runfieldcalculations -- The runfieldcalculations statement performs any automatic calculations associated with the current field.
- signedbinaryvalue( -- The signedbinaryvalue( function converts binary data (a byte, word, longword, or longlongword) into a signed number (see Binary Data).
