This release includes a few minor new features and about a dozen bug fixes.
- There is a new Scale submenu in the Objects menu and in the graphics mode Context menu (right click). This allows for easy scaling of a selected object’s size. There is also a new scaleselectedobjects statement to scale the selected objects.
- New functions: dayofmonth(, dayofquarter( and dayofyear(.
- New binarydatatype( function, which inspects a binary value and returns the type of data inside (if possible), for example Array, Dictionary or Color.
- Fixed View Organizer menus after bringing the View Organizer to the front.
- The Server Administration Wizard Sessions panel now correctly shows the Last Activity time for each session. (Note: This fix only works if you update both the server and the client.)
- Fixed default handling of empty selections in procedure code. Panorama is supposed to skip any bulk modification statements after an empty selection, but except for removeselected/removeunselected, it never did. Now all of the fill statements will be skipped after an empty selection (formulafill, propagate, unpropagate, propagateup, unpropagateup, runningtotal, runningdifference).
- The arrayreplacevalue( function now works even if the value to be replaced appears in multiple consecutive array elements.
- Fixed handling of
"" query parameter in arraybuild, arrayselectedbuild, formulasum, globaldictionarybuild and superarraybuild. (A parameter of "" should have included all records, instead it included none.)
- The arrayrange( function has been fixed so that it works correctly with out-of-bounds array indexes. (There were significant problems with this function if it was passed indexes that were not within the array boundaries. For text arrays this only affected negative indexes. For data arrays both negative and positive indexes out of bounds were not handled correctly.)
- The Text Editor Object Use Field Attributes option now works in Formula mode (previously this option only worked with variables).
- Segmented Button Object now works properly with the info(“clickedobjectid”) and info(“clickedobjectname”) functions.
- Clicking on a form in the Web Status Page now works correctly (displays a blank form).
- The Error Wizard no longer opens a dialog when you click on the error message. (Instead, it copies the error message to the clipboard, and displays a notification. Also added extra error trapping in the Error Wizard when opening a source procedure.)
- The Escape key can now be used to close the About, Memory Usage, and Check Software Update windows.
- Documentation corrections submitted by David Thompson, Peter Newble, Robert Ameeti, Alain Hervé, Thomas Cooper, James Cook. Thank you!
