This release includes one minor enhancement, new commands in the Hide/Show menu, and a handful of bug fixes, especially some important fixes for brand new users who are opening Panorama X for the first time.
- Revamped the Hide/Show menu by Adding the new commands Hide Before Current Field and Hide After Current Field (of course they are recordable). Also, the Hide/Show Fields menu item now shows the current number of visible fields, as well as the total number of fields in the database.
There is new statement, ShowFieldsBetween, which makes a range of fields visible, while hiding all others. For example:
showfieldsbetween “City”,“Zip”
Renaming (or re-titling) a field now works even if there are hidden fields to the left of the field being renamed.
Data entry of accented characters by holding down a vowel key then picking from the pop-up window now works correctly in data cells.
The Summarize & Analyze Dialog now works correctly with fields that have spaces or other punctuation in the field name.
Morph and Morph All Fields no longer allow a carriage return to be inserted into one line text fields, potentially rendering some of the text invisible.
Changed several defaults for brand new users. The Open View dialog defaults to current database, not all databases. The Find/Select dialog defaults to current field, not all fields, and reset search criteria defaults to on, instead of off. All of these settings can be changed at any time in the preferences window.
If favorites get corrupted somehow, Panorama now handles that without error messages or other problems.
Memory usage window did not work the very first time Panorama was launched.
Fixed tool bar pop-up menus so that they would work properly with styled text in a menu item. This is used to display the field count in the revised Hide/Show menu.
When Panorama is launched, the Site License wizard will open any time there is no account, not just on the very first launch. Also, this wizard now displays correctly even when Panorama is quarantined (first downloaded from internet), and revised the way the new user survey is transmitted to the ProVUE server.
Minor documentation corrections.
- showfieldsbetween -- The showfieldsbetween statement hides all fields except those in between specified numbers.
- Version 10.2.4 (released Sep 24, 2026) -- Summary of Version 10.2.4 (released 9/24/2026)
